1st error
debconf: delaying package configuration, since apt-utils is not installed
2nd
warning: mbstring (mbstring.so) is already loaded!
at the end
Status: Downloaded newer image for fancybits/channels-dvr:tve
Creating channels-mapper ... error
Creating channels-frontend ...
Creating channels-mapper-db ...
Creating channels-backend ...
Creating channels-frontend ... error
Creating channels-mapper-db ... done
8d0afbd4a5f2a7c89780e8c61): Error starting userland proxy: listen tcp 0.0.0.0:80: bind: address already in use
ERROR: for channels-frontend Cannot start service channels-frontend: driver failed programming external connectivity on endpoint channels-frontend (cf5b2efc39c7ae610297e69dCreating channels-backend ... done
ERROR: for mapper Cannot start service mapper: driver failed programming external connectivity on endpoint channels-mapper (ef3164d7f6361e5220c701257a096a5bc7dc88a8d0afbd4a5f2a7c89780e8c61): Error starting userland proxy: listen tcp 0.0.0.0:80: bind: address already in use
ERROR: for channels-frontend Cannot start service channels-frontend: driver failed programming external connectivity on endpoint channels-frontend (cf5b2efc39c7ae610297e69dc74cdeed8a7afea4cc83d930624653898da7a21d): Error starting userland proxy: listen tcp 0.0.0.0:8089: bind: address already in use
ERROR: Encountered errors while bringing up the project.
Docker log
Start container channels-mapper failed: {"message":"driver failed programming external connectivity on endpoint channels-mapper (fd26f4a300ac75a92a64daa219da0c9494e849b82d08ffbff71a0ad95803bfbb): Error starting userland proxy: listen tcp 0.0.0.0:80: bind: address already in use"}.
12/02/2020 07:06:47 pm Error Carlos
My biggest problem I am already runnin Channels dvr outside of docker
