The latest DVR pre-release (v2020.09.14.2302) contains an update to the web framework we use for the admin UI. If you use the web UI regularly, we could use your help testing it!
This change is mostly under-the-hood, so the web UI looks and works the same way as before. If you notice something isn't working or not working like it did before, please let us know in the comments below.
