Most channels not working
I'm on Spectrum and everything has been working great for a long while. Today more channels than not quit working (spinning circle). I'm running ubuntu server. I have tried updating chrome browser and rescanning channels. Any suggestions?
Go through the troubleshooting checklist. Make sure you're running the latest DVR prerelease. A lot of TVE channels have been removed.
I ran the trouble shooting and got all green. tied updating to latest prerelease. here is what it says next to some channels in the manage channels this is for A&E: Get "https://link.theplatform.com/s/xc6n8B/qkeYwEZBcigQ?auth=<signatureInfo>GyOQ3uQefUoi6c9HsBcunc0GyVZun%2BIOnY0uT%2FzOh5W5d6e9L8M6GcVOvVoz0ghEIQW3FU2qPBgv6bbygz0AEfT4u2HD6flYOs6%2FdomcoNlumbMh%2FpRslKsz5hXQwclIR7Tla%2FwU6xf6JZfHcCVKIUQMDbH83YMN4PhU4i66%2B20%3D<signatureInfo><authToken><sessionGUID>84479b398e722abe413a1105b83d34a2<%2FsessionGUID><requestorID>AETV<%2FrequestorID><resourceID>AETV<%2FresourceID><ttl>420000<%2Fttl><issueTime>2026-04-17+14%3A31%3A05+-0700<%2FissueTime><mvpdId>Spectrum<%2FmvpdId><%2FauthToken>&format=SMIL&formats=M3U+appleHlsEncryption%2CM3U+none&manifest=m3u&schema=2.0&switch=aetv_east_hls&tracking=true&vpaid=script": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
I get that same thing with my brothers directv login. Missing same channels as my Spectrum
What does that mean?
What version are you running?
tried not tied. I'm running this 2026.04.12.0247
Is there a list of TVE channels that were removed?
Which channels are showing errors?
I don't get A&E with YTTV, so can't check that one.
I went to a&e.com and foxnews.com and can watch both of those
Channels that have the error, a&e, history, fyi, lifetime,fnc, fbn, vh1, vh1p
I don't get the A&E Networks channels (a&e, history, fyi, lifetime) with YTTV. Maybe someone else can verify them.
fnc & fbn work for me.
vh1 & vh1p are known issues
I'm uninstalling and reinstalling now will see how that goes
You might want to do this first
ok, I uninstalled and reinstalled with the same outcome. then I used another pc to install on with the same results. I tried rebooting both pc's same results then rebooted modem and tried again with same results. Very strange because I can login into any of the websites and watch no problem. I did try the update Password also
Did you try step 12 after doing step 10?
If that doesn't work, then do step 14
Also the following may cause issues.
VPN
DNS filtering (like pi-hole/ad-blockers/etc.)
Not using your ISP DNS Servers.
A&E TVE works fine for me with spectrum credentials on server Version 2026.04.08.2108. Ubuntu server as well.
yes i tried step 12 after step 10 and i did do the troubleshooting and submitted it
I appreciate you guys helping.
what is weird to me is the same channels are missing with 2 different logins. one from Spectrum and one from Directv
