Pluto TV Docker Help
If I try to start Docker Desktop from the icon on the dock, I see the menu bar switch to Docker for a second and then it disappears. Any ideas?
Not a Mac person here I am going to tell you what I would try:
1 - Is Docker actually running on the Mac?
2 - Can you get to the pluto-for-channels web page? (http://localhost:8080/)
3 - Try reloading the M3U in channels
I got it to start, but not sure how to fix it. I found a suggestion to try starting it by double clicking on the Docker Desktop icon on the Applications folder while holding the Option/Cmd key, and that started it. But I don't want to have to do that every time I reboot the Mac.
Thanks for the suggestions... I made a bit more progress in my last post and looks like its possible a permissions problem, but not sure how to resolve it. Someone suggested running disk utility on the boot drive so I'm trying that. Will report back on it. People are watching TV now in the house so I'll have to wait a while to do it.
Running Disk Utility first aid seems to have fixed the immediate issue. Docker now persists through a reboot and restarts. But I am getting some funky errors running diskutil that seem to be related to the Mohave update so I could run Docker Desktop. They don't seem to be causing any problems so will ignore from now. One of the google posts I found said that they can be ignored... but doesn't sound that legit to me. So at this point all is running again and all of this had nothing to do with Channels DVR and is apparently some unrelated Mac issue.
I updated to version 1.0.18, noticing the release notes yesterday:
  • Some null metadata caused issues
Just wanted to report that the issue of all Pluto.tv movies are still showing in the guide as "Directed by: (null)"
That’s a different issue and has to be fixed in the client.
Understood, thanks for the reply.
As I've been doing some storage maintenance, I've turned the DVR off and on a couple of times this afternoon. I noticed that every time I turned it back on, it shows in activity "Watching ch9189 Pluto TV Cars from x.x.x.x". This TV has been turned off and has a Tivo 4K Stream that was on that channel a couple days ago. So I turned the TV on and sure enough that was the channel that was active. So I switched it to an OTA channel and then turned the TV off. Its still showing the same in Activity. Is it normal that Pluto would be showing an active channel all the time, even if I'm not watching anything? I'm using Docker. While its not hurting anything for me because I have uncapped bandwidth, I would imagine its going to just run up data usage for anyone that is not.
Normally the TV notifies Android TV OS that it has shut off, and then we turn off the player. Sounds like that's not happening. Either something specific to your TV, or a bug in the TS4K. Can you submit diagnostics after turning the TV back on?
A couple of us are having a problem where channels recorded via Pluto will not persist changing the visibility to Kids. You set it to Kids. It appears to work. And then shortly after its back in Library and not in Kids. See other thread on this... Kids setting not sticking
I was able to get Docker to work and generated the M3U and EPG. However, some of the channels are play the UK version of the channel but the guide is showing the US data. I specifically noticed this on "Pluto TV Action". The guide data is showing what is playing on the Pluto App here in the US but, the m3u has the UK. Any suggestions? I would prefer the US feed if possible.
Is there someone willing to help me set this up on a Synology ds220+. I can’t seem to figure it out. I’m half way there. I have downloaded Docker from the package center and have the container up and running. Can’t figure out what to do from there. The instructions aren’t helping much as I am new to Docker and it is like a foreign language to me. Can someone help with the next steps??
Here is where I am so far.
The directions are on Maddox's docker site: GitHub - maddox/pluto-for-channels: M3U generator optimized for Channels' custom channels.
Add Source to Channels
Once you have your Pluto M3U and EPG XML available, you can use it to custom channels channels in the Channels app.
Add a new source in Channels DVR Server and choose M3U Playlist . Fill out the form using your new playlist URL.
Next, set the provider for your new source and choose custom URL.
Finally, enter your EPG xml url and set it to refresh every 6 hours.
Thank for attempting to help. I am not understanding the directions. How do I make the playlist available to me? All I have done so far is search for the Jonmaddox Pluto-for-channels in the registry and download. Now it appears as running in the container section and it also appears in the image section. What do I do next?
Don’t mean to be a burden just a step by step instruction.
Once the docker is up and running, which it is from your screenshot, you just need to add a new source in Channels DVR Settings. There is nothing else to do in Docker.
Then, using the IP address of the docker computer, follow those steps. (alternatively, if Docker and Channels DVR are on the same computer, you can use 127.0.0.1 as the IP)
I’ve tried that. Using the IP address of the NAS itself port :8080 correct? As well as using the 127.0.0.1:8080 address as well. Both are returning 0 channels. I think I am missing a step.
If you used this command to start the docker:
docker run -d --restart unless-stopped --name pluto-for-channels -p 8080:80 jonmaddox/pluto-for-channels
then 8080 should work. What happens if you use IP of the NAS:8080 in a web browser. Should look like this:
Then you can click on the Playlist and EPG to see that they return data. If not, then I don't know. I'm running DVR and Docker on a Raspberry Pi4, so I don't know about Synology.
How do I use the command to start the docker? I didn’t type any commands or anything. I just downloaded the container, that is all.
You most likely left the port to auto in the synology docker when you were installing it. Double click the container in your screenshot and look at the port that it shows. That’s what you use.
