Project One-Click: All-in-One Installations of Docker Extensions and CDVR Custom Channels
@bnhf .
Here's the post install healthcheck you asked for from our discussion in the PrismCast thread. I'm running Channels in Windows with the server in my C drive and all other DVR folders in my E drive.
ls: cannot access '/mnt/192.168.88.240-8089': No such file or directory
ls: cannot access '/mnt/192.168.88.240-8089_logs': No such file or directory
jq: error (at <stdin>:0): Cannot index string with string "Name"
Checking your OliveTin-for-Channels installation...
(extended_check=false)
OliveTin Container Version 2026.01.27
OliveTin Docker Compose Version 2025.08.25
Checking that your selected Channels DVR server (192.168.88.240:8089) is reachable by URL:
HTTP Status: 200 indicates success...
100  1276  100  1276    0     0   416k      0 --:--:-- --:--:-- --:--:--  623k
HTTP Status: 200
Effective URL: http://192.168.88.240:8089/
Checking that your selected Channels DVR server's data files (/mnt/192.168.88.240-8089) are accessible:
Folders with the names Database, Images, Imports, Logs, Movies, Streaming and TV should be visible...
Docker reports your current DVR_SHARE setting as...
If the listed folders are NOT visible, AND you have your Channels DVR and Docker on the same system:
Channels reports this path as...
E:\DVR
When using WSL with a Linux distro and Docker Desktop, it's recommended to use...
/mnt/e/DVR
Checking that your selected Channels DVR server's log files (/mnt/192.168.88.240-8089_logs) are accessible:
Folders with the names data and latest should be visible...
Docker reports your current LOGS_SHARE setting as...
C:\ProgramData\ChannelsDVR
/mnt/c/ProgramData/ChannelsDVR
Checking if your Portainer token is working on ports 9000 and/or 9443:
Portainer http response on port 9000 reports version 2.33.6
Portainer Environment ID for local is
Portainer https response on port 9443 reports version 2.33.6
Here's a list of your current OliveTin-related settings:
HOSTNAME=olivetin
CHANNELS_DVR=192.168.88.240:8089
CHANNELS_DVR_ALTERNATES=
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
ALERT_EMAIL_FROM=[Redacted]@
ALERT_EMAIL_PASS=[Redacted]
ALERT_EMAIL_TO=[Redacted]@
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
PORTAINER_TOKEN=[Redacted]
PORTAINER_HOST=192.168.88.240
PORTAINER_PORT=9443
PORTAINER_ENV=2
Here's the contents of /etc/resolv.conf from inside the container:
# Generated by Docker Engine.
# This file can be edited; Docker Engine will not make further changes once it
# has been modified.
nameserver 127.0.0.11
options ndots:0
# Based on host file: '/etc/resolv.conf' (internal resolver)
# ExtServers: [host(192.168.65.7)]
# Overrides: []
# Option ndots from: internal
Here's the contents of /etc/hosts from inside the container:
127.0.0.1       localhost
::1     localhost ip6-localhost ip6-loopback
fe00::  ip6-localnet
ff00::  ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
172.21.0.2      olivetin
This is the part we want to get working first, though there's also a problem with the paths you're using.
Typically, when Portainer versions are reported, but not Environment ID numbers, that means there's a problem with your Portainer Token. I'd suggest going into Portainer, and under the dropdown in the upper-right corner for your Username, go into My Account and delete the existing olivetin token and create a new one. Store it in a safe place.
Stop your olivetin stack, and replace the old token with the new and click Update the stack. Rerun the healthcheck and hopefully you'll see ID #'s where there are none now.
Also, while you're at it, you might try replacing your current values for DVR_SHARE and LOGS_SHARE with the values suggested in the healthcheck. So, it'd be:
DVR_SHARE=/mnt/e/DVR
LOGS_SHARE=/mnt/c/ProgramData/ChannelsDVR
and let's see if that fixes the lack of access to those two directories. Windows can be a bit of a pain when it comes to this whole area of Linux vs Windows paths. But those paths should work on recent versions of Windows 11.
EDIT: Also, please confirm your Portainer environment is named local. People have, on rare occasions, changed that default name -- which is another reason this could be failing.
Well, I'm part way there. PrismCast installed and is working, but access to those folders is still not available. I've tried multiple methods to input those values, but the healthcheck still doesn't show them. The container shows the volumes as /mnt/e/DVR/mnt/- for the DVR Share and /mnt/c/ProgramData/ChannelsDVR/mnt/-_logs for the Logs Share.
First, could you just confirm for me that you haven't made any changes directly to the Docker Compose?
And second, could you post your complete list of env vars here (you'll need to make a few manual redactions)? Go into the Environment variables section of the Portainer-Stacks Editor in Advanced mode to grab it.
For example, here's mine:
TAG=latest
HOST_PORT=1337
CHANNELS_DVR_HOST=media-server8
CHANNELS_DVR_PORT=8089
CHANNELS_DVR2_HOST=utheater-pc
CHANNELS_DVR2_PORT=8089
CHANNELS_CLIENTS=appletv4k firestick-master
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Mountain
HOST_DIR=/data
DVR_SHARE=/mnt/dvr
LOGS_SHARE=/mnt/channelsdvr
TUBEARCHIVIST_SHARE=/mnt/dvr
DVR2_SHARE=
LOGS2_SHARE=
TUBEARCHIVIST2_SHARE=
DVR3_SHARE=
LOGS3_SHARE=
TUBEARCHIVIST3_SHARE=
HOST_SFS_PORT=8081
FOLDER=/web
PORTAINER_HOST=htpc6
PORTAINER_PORT=9443
PORTAINER_ENV=2
PERSISTENT_LOGS=false
Confirmed, no changes to the compose. Here's the info;
TAG=latest
DOMAIN=local
HOST_PORT=1337
CHANNELS_DVR_HOST=192.168.88.240
CHANNELS_DVR2_HOST=
CHANNELS_DVR2_PORT=
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
ALERT_EMAIL_FROM=
ALERT_EMAIL_PASS=
ALERT_EMAIL_TO=
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=America/Los_Angeles
HOST_DIR=/data
DVR_SHARE=/mnt/e/dvr
DVR2_SHARE=
LOGS2_SHARE=
DVR3_SHARE=
LOGS3_SHARE=
HOST_SFS_PORT=
FOLDER=
PORTAINER_PORT=9443
PORTAINER_ENV=2
@bnhf PrismCast issues hoping you might have suggestion.
2026/02/05 12:01:07.267708 [ERR] Could not start stream for M3U-prismcast ch11992 FX (Pacific): M3U: Could not fetch playlist from win11pc:5589 (Timeout): Get "http://win11pc:5589/hls/fxp/stream.m3u8": net/http: timeout awaiting response headers
2026/02/05 12:01:07.799016 [TNR] Opened connection to 131718F9/0 for ch1409 FXPHD
Any corresponding action in the PrismCast log?
just tried again, channels log.
2026/02/05 12:52:22.735450 [ERR] Could not start stream for M3U-prismcast ch11954 ABC: M3U: Could not fetch playlist from win11pc:5589: GET: http://win11pc:5589/hls/abc/stream.m3u8: 503 Service Unavailable
2026/02/05 12:52:23.265236 [TNR] Opened connection to 131718F9/0 for ch1004 KOMODT
2026/02/05 12:53:22.934785 [SNR] Statistics for ch1004 KOMODT: ss=100% snq=100% seq=100% bps=6519739,209056-6919904 pps=558,18-593
2026/02/05 12:53:22.934785 [SNR] Buffer statistics for 192.168.50.250 (OnePlus 9 Pro 5G) for ch1004 KOMODT: buf=0% drop=0%
2026/02/05 12:53:22.938969 [TNR] Closed connection to 131718F9/0 for ch1004 KOMODT
PrismCast log.
[2026/02/05 20:52:22.735] GET /hls/abc/stream.m3u8 from 172.24.0.1 responded 503 in 0.513 ms.
The site is currently linked to Xfinity perhaps thats why it is opening the HDHR Prime.
Also noticing the timestamps are not matching up.
Try both the PrismCast URL, and the URL it resolves to in VLC. And, you can also try the URL it resolves to in another browser, as a sanity check. 503 is kind of a weird error, indicating a temporary unavailability, as opposed to a 404 error.
Well the link plays in Edge with no problem.
Does not play in VLC.
I just now clicked on TV provider Xfinity in the no VNC window and got this on screen.
New bnhf/olivetin:latest (aka bnhf/olivetin:2026.03.08 ) pushed this morning with Project One-Click support for two new extensions:
More details here:
And here:
As always with Project One-Click, it's super easy to add and/or delete a project -- which makes it very nice to "kick the tires" on a project with only a few minutes of work.
All with the new integrated feel of running OliveTiin as though it were an integrated part of the CDVR WebUI:
I'm currently setting up a from scratch channels with everything based out of project one click - has worked really well so far - i spun up cc4c and it works great for weather
also installed the weatherstar and it doesn't work - not sure if the issue is connected to olivetin or the app itself
trying to setup adbtuner to work with google streamer and Hulu live. In Olivetin I clicked "
Create an ADBTuner Stack in Portainer + CDVR Custom Channels" button and got the following result:
JSON response from http://192.168.10.10:9000/api/stacks/create/standalone/string?endpointId=6:
"Id": 13,
"Name": "adbtuner",
"Type": 2,
"EndpointId": 6,
"SwarmId": "",
"EntryPoint": "docker-compose.yml",
"Env": [
"name": "TAG",
"value": "latest"
"name": "DOMAIN",
"value": "localdomain"
"name": "HOST_PORT",
"value": "5592"
"name": "HOST_VOLUME",
"value": "adbtuner_config"
"ResourceControl": {
"Id": 30,
"ResourceId": "6_adbtuner",
"SubResourceIds": [],
"Type": 6,
"UserAccesses": [],
"TeamAccesses": [],
"Public": false,
"AdministratorsOnly": true,
"System": false
"Status": 1,
"ProjectPath": "/data/compose/13",
"CreationDate": 1773256412,
"CreatedBy": "admin",
"UpdateDate": 0,
"UpdatedBy": "",
"AdditionalFiles": null,
"AutoUpdate": null,
"Option": null,
"GitConfig": null,
"FromAppTemplate": false,
"Namespace": ""
true
JSON response from 192.168.10.10:8089:
{"error":"failed to load m3u: failed to retrieve m3u: GET: http://192.168.10.10:5592/channels.m3u: 502 Bad Gateway"}
Any ideas?
I should add that I'm running channels in a container on a Synology NAS but I didn't use portainer to build the channels dvr container. If I need to redo channels dvr via portainer I can do that if needed.
No need.
I see CDVR couldn't load the M3U from ADBTuner. But, did the ADBTuner container spin-up OK? Is it running?
actually, the adbtuner did spin up! how do I handle the error ? (thanks for the quick response BTW..)
More info. Actually I can see channels dvr via portainer. Its set to host (vs bridge) mode. I remember needing to set it to host mode because when it was in bridge mode all devices on the same network as the CDVR thought they were remote, so setting it to host mode worked. Probably shot myself in the foot by setting CDVR to host mode.
We could try to figure out why that happened, but you could also just proceed with adding some virtual channels to ADBTuner, and then manually add it as a Custom Channels to Source to your CDVR Server.
The end result would be the same, and it'd faster to carry on I would think.
i re-ran the olivetin button and got no errors. Added google TV streamer to adbtuner and added 3 channels and the m3u looks good and I can see these 3 channels on the CDVR guide. The moment of truth - try to tune to ESPN and watch the Google TV device on a TV. Opens Hulu, gets stuck on Who's Watching profile. I manually pick the only profile that's there (because Hulu is too stupid to know if there is only 1 profile who else can possible be watching!). Reboot, tune to live TV on Hulu (since I'm told this will cause Hulu to remember not to ask who's watching". Try again. This time Hulu returns "Oops. There was an error playing this video". and here we go. Spent $100 on the Google Streamer. Is trying to get Hulu Live working w ADBtuner a waste of time because I'm seeing that Hulu just hates deeplinks? This is why ah4c was invented, right ? Is there any chance Hulu Live will work w ah4c and my shiny new Google TV streamer?
Post a complete log snippet of a failed tune in the ADBTuner thread. There are others using ADBTuner successfully with Hulu, so we should be able to get to the bottom of what's going on.
