yes, v109.
2023/08/21 18:40:30.781753 [TVE] action=version product=Chrome/109.0.5414.74 jsVersion=10.9.194.9 protocol=1.3 revision=@e7c5703604daa9cc128ccf5a5d3e993513758913
Troubleshooting steps to follow, like a checklist
- If you can't watch the network at their Live streaming website, nothing Channels can do. Like nbc.com/live or check availability buttons at Channels Support - TV Everywhere Availability for your Provider
this seems irrelevant since i can't authorize any provider (not specific channels), but regardless yes i can see streams like TBS for example in the browser.
- Make sure your package or container (if running in one) is up to date.
we just did this.
- Update to the latest DVR prerelease version see this article for how
did this earlier.
- Run troubleshooting from the DVR web UI Support>Troubleshooting and make sure all green checkmarks. (If it says Chrome corrupted or not up to date it should offer a green fix button to press.)
all green.
- Make sure your chrome or headless chrome is up to date. (Current included version is 97 or 109)
we just did this.
- Close all browser windows and open a new private/incognito browser window to access your dvr (Some users had to access the DVR web UI remotely or using secure HTTPS to add a source)
have tried incognito. still the same 401 error.
- Open a second tab in the same browser window and login to nbc.com/live , dismiss any popups/notifications your provider may display on login.
- If adding a TVE source, click and HOLD the Login button.
have tried this. no luck.
- Before rescanning individual channels, and before removing a source to re-add, use Update Password under the gear dropdown next to your source in the DVR web UI and just key in your existing Provider password to clear the chromedata folder (likely used with other providers, but known to be used for Spectrum and Xfinity per this post )
- Individually rescan channels with issues using Rescan Channels under the gear dropdown next to your source in the DVR web UI.
i can't do this because i can't get it to even add the provider.
- Reboot your server or restart your package or container if running in one.
have tried this (both server and container). no luck.
- Remove and re-add your source, then individually rescan any channels with issues.
obviously this isn't working.
