BBC America not working
same on their webpage, there is problem with their live stream.
020/06/03 14:31:08.231451 [ERR] Failed to start stream for ch6087: TVE: get https://amchd-lh.akamaihd.net/i/Amc_Hls_1@380947/master.m3u8?hdnea=ip=69.12.88.58~st=1591187437~exp=1591187527~acl=/i/Amc_Hls_1@380947*~id=b18ba0a4-f4d5-4e10-9fdc-c3c1bc845c8d~hmac=2ee16f2cf364a6713063a76a424f4b1c01bc7f08ed6a6b86b5865fd7e1ca66e9: 403 Forbidden 2020/06/03 14:31:10.127817 [HLS] Couldn't generate stream playlist for ch6087-dANY-ip127.0.0.1: TVE: get https://amchd-lh.akamaihd.net/i/Amc_Hls_1@380947/master.m3u8?hdnea=ip=69.12.88.58~st=1591187437~exp=1591187527~acl=/i/Amc_Hls_1@380947*~id=b18ba0a4-f4d5-4e10-9fdc-c3c1bc845c8d~hmac=2ee16f2cf364a6713063a76a424f4b1c01bc7f08ed6a6b86b5865fd7e1ca66e9: 403 Forbidden 2020/06/03 14:31:10.128588 [HLS] Stopping transcoder session ch6087-dANY-ip127.0.0.1 2020/06/03 14:33:03.398566 [ERR] Failed to start stream for ch6087: TVE: get https://amchd-lh.akamaihd.net/i/Amc_Hls_1@380947/master.m3u8?hdnea=ip=69.12.88.58~st=1591187511~exp=1591187601~acl=/i/Amc_Hls_1@380947*~id=d901fa2b-c7f4-4be3-936a-cc270ba6cf4a~hmac=2a74ec39d7fa453fb5ec84ced67cb167e5f3b8fc6a2b4d53009880c2fcbedc36: 403 Forbidden 2020/06/03 14:33:06.892220 [HLS] Couldn't generate stream playlist for ch6087-dANY-ip127.0.0.1: TVE: get https://amchd-lh.akamaihd.net/i/Amc_Hls_1@380947/master.m3u8?hdnea=ip=69.12.88.58~st=1591187511~exp=1591187601~acl=/i/Amc_Hls_1@380947*~id=d901fa2b-c7f4-4be3-936a-cc270ba6cf4a~hmac=2a74ec39d7fa453fb5ec84ced67cb167e5f3b8fc6a2b4d53009880c2fcbedc36: 403 Forbidden 2020/06/03 14:33:06.892250 [HLS] Stopping transcoder session ch6087-dANY-ip127.0.0.1
Is anyone else having an issue with Paramount?
not_found: Sorry, this video is not found or no longer available due to date or rights restrictions.
Yes, it works there.
Fixed in latest pre-release build. Click-and-hold the update button to upgrade.
Thank you. That fixed the issue. Love the product and the support. You are appreciated!
I no longer get Fox Sports Southwest or ABC with my Directv TVE. I've had access to both for months
I've lost Fox Sports Midwest, which is now Bally Sports Midwest. I'm wondering if its because both have been taken over by Bally Sports... Can someone please look into this?
Bally Sports RSNs are all DRM protected now, and have been removed/disabled.
See also:
DirecTV has recently changed their backend authentication server/login process, and it has been causing some problems. Updating to the latest pre-release, removing the source, and re-adding DirecTV seems to be working for most people as a fix.
DirecTV also allows for creating "secondary" accounts in addition to the primary account. For most networks, TV Everywhere access is granted to these secondary accounts. However, the authentication only works for networks using the newer login form. Networks that are still using the old login form (NBCUniversal, A+E Networks, ESPN) will fail with a username/password mismatch error. Unfortunately, at this time that means you cannot use secondary accounts with Channels, because authentication against NBC is what Channels is currently using to determine if it should continue trying to verify the account.
I can confirm this statement.
When I readded the DirecTV source, it seemed to be stuck for a very long time (several minutes) on verifying access to NBC (the first channel in the list). When I saw that, I thought TVE was over in Channels and that would have been the end for me because this is my primary source. It finally got through and I have my 181 channels back.
For now.
Re-adding the source seems to be taking an inordinate amount of time. Also, some channels from a network will scan in, and others may not; for example Hallmark did not scan in, but Hallmark Drama did. In those cases, selectively rescanning the individual channels with issues seems to be the way to go.
All, I’m having issues with the NFL channel authenticating properly with direct TV. All the other channels are authenticating fine and I can authenticate properly using the nfl.com website and the nfl Apple TV app. The error I’m seeing is “no login form found”
Click the down arrow next to Check for Update and select Prerelease.
CMT is the only ViacomCBS channel with this problem. It was still working two days ago.
I'm able to watch live on their website.
Version 2022.02.22.1927
Up to date!
Logs have been submitted as 6c3c1b7a-8595-4e7c-a9a0-cb2853404df7.
Update: I was very hesitant to do a full rescan in fear of losing more channels and sure enough, I lost 22 channels now with the same error: FOX (WNYW), CC, MTV, CMT, Paramount, CNN, CNNI, TBS, TBSP, TNT, TNTP, and more.
I'm able to watch live on websites.
Problem fixed. It turns out I had to reset my DirecTV password. More details in the linked thread: DirecTV TVE lost 28 channels due to error 0066
Anyone having issues with NewsNet (6759)?
Getting this;
2022/08/30 11:46:57.683525 [ERR] Could not start stream for ANY ch6759 NEWSNET: TVE: Stream Not Available
2022/08/30 11:46:57.684096 [TNR] Opened connection to M3U-DirecTVviaM3u for ch346 WYBNLD8 (NEWSNT)
2022/08/30 11:46:57.684674 [TNR] Closed connection to M3U-DirecTVviaM3u for ch346 WYBNLD8 (NEWSNT)
2022/08/30 11:46:57.685228 [SNR] Buffer statistics for 192.168.3.55 (Tivo - Office) for ch346 WYBNLD8 (NEWSNT): buf=0% drop=0%
Can someone please check and confirm NewsNet (6759) is working for them? Thank you
That's one of the free channels everyone gets, no matter which provider.
Isn't working for me either.
[ERR] Failed to start stream for ch6759: TVE: Stream Not Available
Watching it right now at Livestream - NEWSnet - More News. More Often (yournewsnet.com). Broken in Channels for some reason.
Better to create a separate post about it outside of this thread since this is not related to DirecTV.
