I'm also wondering how Favorite channels, OTA vs CABLE vs TVE, HD vs SD, higher numbered vs lower numbered channel, etc. fit in the priority determination for which device/channel to record from.
Does tuner priority take precedence even if a lower priority device has the channel favorited and the higher priority device does not?
So assuming you have the setup and device priority that KFStein has...
Hypothetically let's say the same program is available to record on all 4 devices at the same time.
Does it always use tuner priority over OTA vs CABLE vs TVE, HD vs SD, Favorite channel vs not favorite channel, higher numbered vs lower numbered channel, etc.
